Hi there,
I have a mosquitto broker on a remote server and I want to connect to it through Kepware server. As far as I understand I need to add the client certificate and key to the Windows Certificate Store. Can you guide me where should I add the certificates? Thankyou!
I found the problem. In the Certificate Store -> Feature it was not selected MQTT Client.
Hi @SachinSharma , thankyou for you time.
I have followed that tutorial before and I added also the client certificate. I think it is somehow working, though on the server I now get the following error: „SSL routines:ssl3_get_record:wrong version number”.
It was an invalid certificate, now I connected an IoT gateway to the server, but a channel MQTT Client doesn't want to connect to connect, it says: 'socket error', 'TCP/TLS connect failure'. Any idea why is that ?
In kepware I get 'socket error', 'TCP/TLS connect failure' but in mosquitto I get 'Client <unknown> disconnected: Protocol error.'
