The label size and color reset to what i have mentioned in theme while i navigate between mashups in Thingworx 8.5. After full browser refresh it comes back to the specified one in design time, else it stays at theme specified values. i cant have all the labels of same size, so one specific size in the theme will not help (i.e. header label will have larger fonts, other labels will be smaller). how to resolve this?
Each widget still supports custom css class, so you can use that to group your labels and apply separate css/themes
Ok i ll try that . Thanks
Hi @psskps.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
