Is it possible to update layout (background colors) by using services?
I don't think so out of the box. I've never seen a Dynamic Style on Mashup ( Bindable ) on any standard TW widget.
You may try with building your own UI extension...
The maximum that I've seen with Standard widgets it's to have optional styles based on states, but this limits you on being really dynamic styling.
Thanks Carles,
That's what I figured based on the research I did prior to posting my question. I was hoping I had missed something.
