Layout Footer Issue
pbaierl
Layout Footer Issue
I am having issues with the layout footers.  The footers are appearing over the top of the first row.
I have a screen setup that has a header, a footer, and one row.
Here is how I have my layout configured in Composer (color coded to see the regions better)
Here is what my mashup looks like when I view it:
Any thoughts on how to correct this issue?
I am using version
This is a bug on 7.2.3 for sure, update to 7.2.4, ( 7.2.3 it's totally unusable )
5 REPLIES 5
dmoon
(To:pbaierl)
I think this is a bug on ThingWorx 7.2.3-b48 at least. I didn't test all the 7.2 versions, but I did on the exact same version that you are using. However, I also tested on 7.1.2-b6, it works fine as you can see below.
If you have a SCN, please report this to PTC tech support (support.ptc.com) by opening a case so that they can make this.
Daniel
pbaierl
(To:pbaierl)
Thanks Carles and Daniel.
I will try to have everything pushed to version 7.2.4 and I will open a case for this issue.
Don't open a case, it's already resolved on 7.2.4.
ok thanks.
