@AC_9552412 ,
From the screen capture you added code to "googlemap.ide.js".
There should also be code added to "googlemap.runtime.js" which makes the approate updates.
The updates include adding the option "drawingControl: true," to options when the item is checked.
You also added the drawing library:
googleMapsConnectionString = _invoker.result.rows[0].GetGoogleMapsConnectionString + "&libraries=drawing";
When defining an instance of the Google Map you need to create an instance of the map object. This looks like
= new google.maps.Map(document.getElementById("map"),
from the Google Maps Documentation. When reviewing the "googlemap.runtime.js" we find:
thisWidget.map = new google.maps.Map(document.getElementById(thisWidget.jqElementId), options);
This creates a Google Map object. From the google documents you need to load the drawing manager. You need to add code which looks like:
thisWidget.drawingManager = new google.maps.drawing.DrawingManager({
    drawingMode: google.maps.drawing.OverlayType.MARKER,
    drawingControlOptions: {
    position: google.maps.ControlPosition.TOP_CENTER,
	drawingModes: [
	google.maps.drawing.OverlayType.CIRCLE,
	google.maps.drawing.OverlayType.POLYGON,
	google.maps.drawing.OverlayType.POLYLINE,
	google.maps.drawing.OverlayType.RECTANGLE,
    markerOptions: {
       icon:					"https://developers.google.com/maps/documentation/javascript/examples/full/images/beachflag.png",
    circleOptions: {
	fillColor: "#ffff00",
	fillOpacity: 1,
	strokeWeight: 5,
	clickable: false,
	editable: true,
	zIndex: 1,
thisWidget.drawingManager.setMap(thisWidget.map);
The above is based on the Google Maps https://developers.google.com/maps/documentation/javascript/examples/drawing-tools
Let me know if you have any questions.
Peter
@AC_9552412 , I have done one simple modification to the Google Map Widget, I added "NiteMode" to the available map skins. There is more to modify then adding a line to the metadata.xml file.
If you can explain what you options expect to see in the Widget,
I may be able to point you in the proper direction.
If you are expecting to see a new control or option you would need to update googlemap.ide.js or googlelocation.ide.js. There would also be a matching update to the googlemap.runtime.js or googlelocation.runtime.js to make the UI change functional.
Hope That helps
Peter
Can you provide an example of a field which is not available.
If you look at the current Google Map Widget
The infotable allow shapes and route data to be displayed.
Is this the tool bar you are trying to add?
Can you share how you changed the configuration to add the libraries?
That is the bar I want to add
Hi @PEHOWE,
All the options you see in your image are displayed but this option should be displayed, which is the one I'm missing.
@AC_9552412 ,
	drawingModes: [
    markerOptions: {
    circleOptions: {
	fillOpacity: 1,
	strokeWeight: 5,
	clickable: false,
	editable: true,
	zIndex: 1,
Peter
Hi @AC_9552412
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
