I have installed Thingworx 9.1 with Postgre SQL using Thingworx Foundation installer on last week. Installation was done successfully and license also applied. Today I have observed 2 license files.
ignored_license_capability_response.bin,successful_license_capability_response.bin. Why it is generated 2 license files. Please refer the attached screenshot. This is first time used Foundation installer on fresh system.
Latha
Hi @vi1.
It appears that your first attempt to apply the license failed. Two days later, it was successful.
You can safely remove the file called ignored_license_capability_response.bin. It's best to never have more than one *.bin file in ThingworxPlatform.
--Sharon
Hi @vi1.
--Sharon
Thanks you for response.
First time it was successful. After that, It was generated ignored one file and successful one file.
I have confusion do I need to go with foundation installer or manual installation? Till Thingworx 8.5 including HA configuration, we have followed manual installation and generated license key manually in all dev and production environment.
Latha
Thank you for clarification.
I will go with Thingworx Foundation installer in all DEV and Prod environment.
Vidyullatha
Hi @vi1.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
Still observing 2 license files generation one is with ignored and another one is with "successful" after deleting one is with ignored file generated earlier.
Latha
I have deleted ignored one. I will observe next 1 week. If observe same issue, will raise support ticket.
Latha
Hi @vi1.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others in the community.
--Sharon
