When trying to create a user in Thingworx, the following error is showing up on the screen:
"License is not available for Product: TWX_PLATFORM Feature: twx_named_user"
I tried out the PTC Knowledge Centre but didn't find any solution. Why is it occurring?
Thingworx Version: 9.7.0-b47
Hi @slangley ,
Thanks for the response. Followed the same as per your suggestion. During the last time, it looks like I made a mistake. When we were using the old License Portal, we just added the device ID and got the license file, but as per the latest License Portal, we needed to select the products that would be part of the license. I missed selecting the 'Thingworx User,' which caused this issue during product selection.
When I created a new license file with the 'Thingworx User' product selected in the latest License Management Portal and tried to create a new user in the Thingworx Composer, the error vanished, and users are being made now.
This is a problem statement. What is your specific question?
You can check your available licenses in the licensing subsystem.
This will list which licenses are available. They might be expired.
Unfortunately, it's somewhat difficult to determine which part numbers in the License Mgmt tool contains the features required for ThingWorx. There are a number of things to be aware of:
Please let us know if you continue to have issues and I can open a case to walk you through the process.
--Sharon
Hi @slangley ,
Glad to hear you resolved it.
Before generating a new license, I recommend taking a screenshot of the existing licensing features in Composer (Monitoring > Subsystems > LicensingSubsystemSettings), and then do a comparison once the new license is installed to confirm that no features are missing.
Please feel free to mark your last post as the Accepted Solution for the benefit of others in the community.
--Sharon
