Limit in number of users creating from an extension
ses
Hey Geeks,
I was trying to create a set of users, from an custom extension created by me.
Inside a loop, I need to create n number of users.
Please see the code snippet;
for(int k=0; k < 3 ; k++) {
  String userName = "testUser" + k;
  services.CreateUser(userName, "Test Desc", null, "pwd");
The first user(testUser0) was created successfully in the first iteration.
But in next iterations testUser1 and testUser2 are not created in Thingworx.
The exception I am getting is ;
com.thingworx.common.exceptions.InvalidRequestException: User limit reached; Please Upgrade to Paid Version
        at com.thingworx.system.managers.BaseManager.createEntity(BaseManager.java:211)
        at com.thingworx.contentmanagement.ImportProcessor.processImport(ImportProcessor.java:456)
        at com.thingworx.resources.entities.EntityServices.processImport(EntityServices.java:130)
        at com.thingworx.resources.entities.EntityServices.CreateUser(EntityServices.java:395)
        at com.test.CtsServiceThingTemplate.reloadPicassoDetails(CtsServiceThingTemplate.java:56)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at com.thingworx.common.processors.ReflectionProcessor.processService(ReflectionProcessor.java:170)
        at com.thingworx.handlers.ReflectionServiceHandler.processService(ReflectionServiceHandler.java:45)
        at com.thingworx.things.async.AsyncHandler.run(AsyncHandler.java:42)
        at java.lang.Thread.run(Thread.java:745)
Can anyone help on this?
Hi Sujith,
The messages states that you reached the user limit, that you should go for the paid version.
Carles.
7 REPLIES 7
Hi Sujith,
Carles.
ses
(To:CarlesColl)
Hi Carles,
Thanks for your reply.
But I do have only 3 users created so far, and each time when I run the code I could create one more user.
ie. the new user is created in every first iteration only at the time of the for-loop execution.
With the below code, I can create n number of users in TW.
Issue is only when I am using this code inside a for-loop.
Sujith
mhollenbach
(To:ses)
Whatever server you are using is not a paid version and this is how we are limiting you from creating more users than allowed.
Meghan
ses
(To:mhollenbach)
Thanks Meghan and Tori, for the reply.
ttielebein
(To:ses)
Where is your ThingWorx instance hosted? Is this in a tutorial on the Developer Zone?
ses
(To:ttielebein)
ThingWorx instance is hosted in DeveloperZone only
ttielebein
(To:ses)
Ah, yes, so programmatic creation of users is disabled in Developer Zone instances, and that explains the error you are seeing. Sorry for the inconvenience there!
If/when you decide to buy the paid version, this will not be an issue anymore.
Hope this helps!
Tori
