Line Chart X Axis Ticks Background
pshashipreetham
18-Opal
Can we change the background colour of the line chart X-axis ticks based on the Data in a column?
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
Thanks for the input, @PEHOWE , I had a word with the user and went around with WorkAround.
I have used StateDefinitions in the Line Chart:
  1. Create a State definition with the Condition
  2. Assign it to the Line Chart
  3. Then, pass the X-Axis Label Value to the property that gets created when a StateDefinition is added to line chart.
  4. In My Case, the Property was DataSeriesStyle_Yes
  5. Once the Property Value is added then the Pointer on the Line chart color changes based on the StateDefinition
Shashi Preetham,
2 REPLIES 2
@pshashipreetham , I took a quick look at a mashup I had with a legacy Chart widget. There did not seem to be an identifier for the tick mark on the x Axis.
If you want to change all the tick marks that might be possible. If you are looking to set each one based on some other value I don't see a way.
If you can provide the ThingWorx version you are looking to use and the widget name you might get a better answer.
Also provide the use case where this feature would provide a better value to the user.
Shashi Preetham,
