MQTT connection issues
DF_9703795
9-Granite
Hi everyone,
I don't get why my "TestMQTT" Thing doesn't connect to my MQTT-Broker.
Basically i did this:
I created a NewThing with ThingTemplate "MQTT"
in Configuration I tried to use "test.mosquitto.org" with 1883
This should be enough to get the "green connect icon", or do I miss something?
I use ThingWorx 9.1.0 and MQTT_Extension 2.1.0.
Thanks for any kind of help!
MQTT 4.0.1 is available on PTC support portal Software Downloads page> Thingworx Foundation> Release 9.1> Thingworx MQTT Extension or you can follow this link.
UPDATE: As of December'22 the latest version of MQTT Extension is 3.1.0
You should use the latest version of MQTT extension 4.0.1 with Thingworx 9.1. I was able to connect TestMQTT thing on my 9.1 instance following the steps you provided.
Where do I get MQTT-Extension 4.0.1? The latest i found was 2.1.0.
SD_9693145
(To:SachinSharma)
MQTT extension is not there on the support site
slangley
(To:SD_9693145)
Hi @SD_9693145
We've made some changes per this announcement.  However, since MQTT is not referenced, I am following up for clarification.
--Sharon
