Hi everyone,
I don't get whats wrong here!
I created two MQTT-Things and configurated them to the same Server, (test.mosquitto.org). I made the same steps for each thing, but one is connected and one not.
I created them last Friday and it works and today I always get these Errors:
I attached the two things, maybe it is a problem with my thingworx server?
Fischertechnik_DaFe_Order: works and is connected
Fischertechnik_DaFe_SU: doesn't connect anymore since today
Thanks for any kind of help!
Hi @DF_9703795,
Was Tomcat and/or the ThingWorx server restarted since Friday ? It can happen that MQQT Things have a hard time reconnecting after a Tomcat restart, especially if you are using an older version of the MQTT extension (latest one is 4.0.1). This is usually solved by saving the MQQT Thing. Does it make a difference on your save if you do a Save on the Thing that is failing to connect ? Another (similar) possibility would be to run both services RestartThing and then EnableThing on that MQTT Thing.
Thanks for your help!
I don't know if it got restarted since Friday.
I will try this, but at the time it even got worse and I am not able to open the thingworx composer (see attached picture).
Is this a licensing problem?
Or maybe it doesn't let me in, if there are too much user currently working?
At first glance this does not seem license related, however you can double-check if you have a valid license by going to Monittoring > Subsystems > LicensignSubsystem and check the expiration dates of your features.
Could you attach today's ApplicationLog.log (located under ThingworxStorage/logs) ? Those might help understand what kind of issue is affecting your server.
