Mailserver Thing
KN_9954684
Mailserver Thing
[message: Unable to Invoke Service SendMessage on EmailAlertsThing : Could not connect to SMTP host: smtp.gmail.com, port: 25]
Getting the above error when trying to run sendmessage service .
Please help me!
@KN_9954684
Please check the smtp ports they may be blocked at firewall/network level. Simple way to verify it, is telnet to smtp server,
telnet smtp.domain.com <port#>
KN_9954684
(To:SachinSharma)
Tried the above command but it shows blank screen
Please share the screenshot of the blank screen you are getting.
Hello @KN_9954684
Are you using the following configuration on mail thing?
  • Use SSL:-Yes
  • Use TLS:- No
  • POP3 Server Port:-995
  • POP3 Server:-POP.gmail.com
  • SMTP Server Port:-465
  • SMTP Server:-SMTP.gmail.com
PLease share some screenshots to help us understand it more.
Om Dukiya
