Hi all,
I am trying do download to Eclipse Plugin for ThingWorx from Marketplace.
But when I click on continue button load the same page. Follow image below:
Someone is with the same problem?
If it still doesn't work, try to:
/ Constantine
I have tried to download the extension and in my case it is working fine, after clicking Continue, there is another screen where you need to accept some terms.
Please check the network connectivity and also if your account is fine.
Raluca Edu
/ Constantine
