I am new to thingworx. I am using Hosted Server, and try Thingworx Foundation Quickstart example. In Create Application UI step, after add New Marshups, select the Design, the Mashup Builder does not showup, so can not select Widgets tab.
Hi @W123.
This sounds like a licensing or permissions issue. What is the url for the site?
Regards.
--Sharon
Hi @W123.
Please let us know if you are still experiencing issues. if you have resolved it, your follow-up post to explain the issue would be much appreciated. This will help others on Community who may have similar issues.
Regards.
--Sharon
