In Thingworx 9.1 version, is there an option to export(Download) a Mashup page into to PDF format.
Sri1
Hi @Sri1
Just to add, there is no OOTB widget provided by PTC to export your Mashup into PDF in any supported Thingworx release. There used to be a PDF extension on PTC Marketplace in past but that as well has been taken down sometime back so as mentioned in earlier comment you can always create your customized extension to achieve add-on functionality you are looking for.
Packaging and Deploying Applications Built on the ThingWorx Platform
Create A Mashup Widget Extension
Hello @Sri1
Thank you for reaching out to PTC.
Please check below community post and see if it helps you with your use case
https://community.ptc.com/t5/ThingWorx-Developers/Export-a-mashup-to-PDF-file/td-p/662306
Please feel free to reach out to us , in case of any question/concern
Toolika Dixit
Hi @Sri1
Hi @Sri1.
If you feel that your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
