Mashup PDF Export 9.1
Sri1
In Thingworx 9.1 version, is there an option to export(Download) a Mashup page into to PDF format.
Sri1
suverma
(To:Sri1)
Hi @Sri1
Just to add, there is no OOTB widget provided by PTC to export your Mashup into PDF in any supported Thingworx release. There used to be a PDF extension on PTC Marketplace in past but that as well has been taken down sometime back so as mentioned in earlier comment you can always create your customized extension to achieve add-on functionality you are looking for.
Packaging and Deploying Applications Built on the ThingWorx Platform
Create A Mashup Widget Extension
tdixit
(To:Sri1)
Hello @Sri1
Thank you for reaching out to PTC.
Please check below community post  and see if it helps you with your use case
https://community.ptc.com/t5/ThingWorx-Developers/Export-a-mashup-to-PDF-file/td-p/662306
https://community.ptc.com/t5/ThingWorx-Developers/Do-we-Have-PDF-export-option-Extension-from-Mashup...
https://community.ptc.com/t5/ThingWorx-Developers/Is-there-any-way-to-generate-a-pdf-of-Mashup-by-on...
Please feel free to reach out to us , in case of any question/concern
Toolika Dixit
suverma
(To:Sri1)
Hi @Sri1
slangley
(To:Sri1)
Hi @SR1.
In addition, we have an Ideas forum where customers can post their requests.  With enough votes, the request will be considered for a future release.  There is already a request for a pdf extension that you can vote for here.
--Sharon
slangley
(To:Sri1)
Hi @Sri1.
If you feel that your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
