Hey guys
I have gone through all the Widget creation documents, but cannot find the "Mashup Widget Custom Dialog API" documentation being referred to. I need to create a configuration page for one of my widgets, but I have no idea how to do it.
Is there any documentation that specifically describes how to use the customEditor and creating the TW.IDE.Dialogs.xxx dialog that I can use to set properties of my widget (using eclipse)?
Regards
Anco
Hi Anco, sorry for limited detail on that in the available documentation - i'll check this out and will get back to you.
Hi Anco, The better documentation that you may get it's going through widgets that already have Configuration ( Grid, Data Filter, Property Display ) you can download it from the server web folders. Best Regards, Carles.
Quick update, an enhancement Jira ticket has been opened to address the missing detail on this topic. This can be tracked here in the KCS article https://www.ptc.com/en/support/article?n=CS276506
Update: R&D has closed this enhancement Jira with statement that Widget API is an old reference document and shouldn't be used anymore. Instead please refer to Extension Development Guide
