I would like to ask about if i chose the dynamic Mashup, so the visualization will be adapted automatically to the screen resolution?
As this is my working arera but when i make view mashup its not covered all the screen
That looks like you have a fixed-size Shape on a dynamic-sized Panel in a responsive mashup.
Widgets will only be responsive when they are dropped into a dynamic region.
Hi Karim BADR, Try using layout widget to create various columns and rows. Then place your responsive widgets in the cells and it will cover the complete cell.
If you use a Panel widget anywhere in the Responsive Mashup; that part will be Static.
OK Thanks alot
Otherwise I define the resolution of the screen where I work (eg 1920*1080)
