Hello everyone,
I'm developing a thingworx widget extension and i was trying to build a table based on an infotable returned from a certain service.
When the service returns the infotable data, the datashape is not ordered as i defined on the thingworx datashape.
The below image represents the datashape that i created:
And the service returns, on widget extension, this order:
I want to receive original order from datashape.
Is there a way to fix this problem?
Thank you
Best regards,
Frederico Silva
Hi Constantine,
Sorry for the later answer.
Yes, i found that ordinal property that you mentioned the it fixed the problem.
Thank you very much for your answer.
Hi FredSilva92.
Which version of ThingWorx are you running? We'll need to investigate. Can you also provide your extension?
--Sharon
Hi Slangley,
Thank you for your answer.
I'm using ThingWorx 8.5.0-b12 version.
Unfortunately, i cannot provide my extension. Sorry about that.
Hi @FredSilva92.
You should consider upgrading to the latest patch release of the product. A number of bugs have been addressed since the release of 8.5.0.
We'll try to do some testing to see if we can recreate the issue.
--Sharon
Ok i will consider that,
Thanks Sharon
Hello @FredSilva92,
Datashape fields have ordinal property, maybe it can help ordering them?
Constantine
Hi Constantine,
Hi @FredSilva92.
If one of the previous posts answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
Hi Sharon,
Sorry for later answer,
yes, i've already marked as accepted solution.
