Mashup widget extension - infotable datashape is not in correct order
FredSilva92
Hello everyone,
I'm developing a thingworx widget extension and i was trying to build a table based on an infotable returned from a certain service.
When the service returns the infotable data, the datashape is not ordered as i defined on the thingworx datashape.
The below image represents the datashape that i created:
And the service returns, on widget extension, this order:
I want to receive original order from datashape.
Is there a way to fix this problem?
Thank you
Best regards,
Frederico Silva
1 ACCEPTED SOLUTION
FredSilva92
(To:Constantine)
Hi Constantine,
Sorry for the later answer.
Yes, i found that ordinal property that you mentioned the it fixed the problem.
Thank you very much for your answer.
8 REPLIES 8
slangley
23-Emerald II
(To:FredSilva92)
Hi FredSilva92.
Which version of ThingWorx are you running?  We'll need to investigate.  Can you also provide your extension?
--Sharon
FredSilva92
(To:slangley)
Hi Slangley,
Thank you for your answer.
I'm using ThingWorx 8.5.0-b12 version.
Unfortunately, i cannot provide my extension. Sorry about that.
slangley
23-Emerald II
(To:slangley)
Hi @FredSilva92.
You should consider upgrading to the latest patch release of the product.  A number of bugs have been addressed since the release of 8.5.0.
We'll try to do some testing to see if we can recreate the issue.
--Sharon
FredSilva92
(To:slangley)
Ok i will consider that,
Thanks Sharon
Hello @FredSilva92,
Datashape fields have ordinal property, maybe it can help ordering them?
Constantine
FredSilva92
(To:Constantine)
Hi Constantine,
slangley
23-Emerald II
(To:FredSilva92)
Hi @FredSilva92.
If one of the previous posts answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
FredSilva92
(To:slangley)
Hi Sharon,
Sorry for later answer,
yes, i've already marked as accepted solution.
