I tried giving mashup name in 'Name' property of master mashup.But it is not showing up in runtime. Please correct me if I am using it wrong way?
Hello @krishnakomal123,
You need to specify Master's mashup name on the contained mashup's "Master" property.
/ Constantine
As far as I understood from the picture, you are giving a name in the bindings, so actually you bind your mashup with that master.
The name of a mashup can be set in DisplayName property.
Hope it helps,
Raluca Edu
I tried by directly binding to the property but it doesn't work.
not sure exactly what is the ask here
but you can try setting the value of "Title" in your master mashup and then probably you may see it at runtime on browser
/ Constantine
