Maximum records in datatable and stream.
dgurumukhi
6-Contributor
Hi Guys,
Does anyone has idea, that how much records a datatable or stream can hold?
Dushyant
There is no limitation on the maximum rows on data tables, but if a data table has more than 100 000 rows you will notice a performance issue and it is recommended to use an external database.
Please find more here: http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Composer/DataStorage/SizingLimitsofDatatables.html#wwID0EFIYR
Raluca
2 REPLIES 2
Raluca
slangley
(To:raluca_edu)
Hi @dgurumukhi.
If Raluca's response has answered your question, please mark it as the Accepted Solution, for the benefit of others who may have the same question.
--Sharon
