Menu Navigation and Sub menu with Horizontal alignment
VS_10550403
Hi ,
I need to create Menu and subMenu with Horizontal Alignment of Menu item. as shown in attached file.
how to achieve this in Twx 9.3.0 , with Icon need to add Menu Item. what widget is suitable here if we see Sub Menu as well in small popup.
Vaibhav S.
Ashritha
(To:VS_10550403)
Hi ,
Make the settings as follows:
Then you will be able to achieve following
Hope this Helps!!
6 REPLIES 6
You can use menu as Type while creating menu item.
Hi @Sathishkumar_C ,
I will get menu but how we can show sub menu in small popup as shown in attached file.
there is no option to select Target as popup. only new page and replace page is there. pls can you elaborate more on this.
Vaibhav S
Ashritha
(To:VS_10550403)
Hi ,
Hope this Helps!!
Hi @Ashritha ,
It looks good , It may work . pls can you tell me what is menu data , how many fields in infotable ? For submenu how it will take data from infotable ? pls ellaborate on menu Data >infotable binding.
Hope you reply soon.
Vaibhav S
jensc
(To:Ashritha)
I am also interested in how you got icons in your sub menu.
It doesn't seem possible using the composer functions.
Is it from the "MenuData"?
Jens
Try with following support document. Hope it will be helpful to define menu items with Infotable.
