Is it possible while using the expand and collapse option for left sidebar where I place a menu to not only collapse the entire menu but to show the icons on collapse.
When I click on collapse icon the menu is completely getting collapsed but I wanted the menu icons to appear and text to collapse. Is it possible in thingworx?
Set the menu as a submashup, and create two mashups (collapsed and uncollapsed menu) and then using the Expanded property on the Left Sidebar load one or the other, should work.
