I’m planning to upgrade to a newer version of SCPA and need to migrate all my entities with the SCPA configuration. Can someone assist with the steps or provide best practices for the migration process?
To upgrade to a new version of SCPA, follow these steps:
Export Existing Entities:
Export all entities created with the current configuration.
Import and Update Configuration:
Import the configuration into the new version.
Test the Platform:
Verify that the platform functions as expected.
Complete the Upgrade:
Once everything is working as expected, the upgrade is complete.
Hi @SD_10908519,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster, as well as articles on our Knowledge Base.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Can you be specific about which version of Thingworx / SCPA you are migrating from and to? The tools are different depending on the upgrade path.
Test the Platform:
