Multi regional ThingWorx deployment on Azure or other cloud vendor
VK_10079185
8-Gravel
Can we deploy ThingWorx HA in AKS multiregional cluster to achieve active/active and highly available configuration?
Hello @VK_10079185 ,
Yes, we can deploy ThingWorx HA in AKS multiregional cluster.
Can you pls share more details like version of TWX you are using?
Regards
Bhawna
ThingWorx version is 9.3
Can we deploy this in Active-Active mode with the nodes distributed across AKS regions?
Hello @VK_10079185
Let me check that with the respective team.
Regards
Bhawna
The active/active HA is supported within a single Azure region in Cloud. Also, We do not recommend or support that for any infrastructure. A second region could be considered as part of a disaster recovery solution. pls check the help centre document linked below which explains your query in detail:
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/ThingWorxHighAvailability/OverviewOfThingworxHighAvailability.html
Let me know if you need anything further.
Regards
Bhawna
