Can we have multiple Thingworx Composers 8.1 connecting to one Analytics Standalone 8.1 (This includes Analytics Extension) ?
If so, can someone provide the steps to perform this ?
Karthik
Hi Karthik
It depends what you mean by different ThingWorx Composer.
If you have one instance of ThingWorx Core you can start several Composer form different clients, then those can connect to one ThingWorx Analytics Server. The main access is usually through the ThingWorx Builder mashup. once the Settings menu is set to the ThingWorx Analytics Thing, then each client will connect to that same one or can change to connect to a different ThingWorx Analytics.
However if you mean different ThingWorx Core instances, then the answer is no. ThingWorx Analytics Server register to one ThingWorx Core server during startup and only one.
So you can have multiple ThingWorx Analytics Server registered to the same ThingWorx Core but one ThingWorx Analytics Server can register to only one ThingWorx instance.
Hope this helps
Kind rgeards
Christophe
