Can we have entity name as suffix for naming the entities in thingworx? As per the best practices in Help document, it says companyname and component name. But can we have entity name as suffix? Is that the best practices?
SV.
Best practice is best practice, that isn't a rule nor is it enforced within ThingWorx.
You can use any naming convention that suits you best.
As general best practice I would say that you should be consistent and that your chosen naming convention should not produce ambiguity.
