I need to capture logged in user id(through session) before mashup loads.
Then you can use REST call to get the result or visit composer directly?
Resource: CurrentSessionInfo - GetActiveUsers service.
GetActiveUsers will give me the whole list , I need the current user . Also I want to access this info in index.html itself.
Then try CurrentUserInfo resource - GetCurrentUser service
Did you get a chance to check previous response on this thread. If you think that is solution of your question please mark that reply accept as solution for the benefit of other community users.
Mohit
