Need to display user presence and absence time slot - Please Suggest the best appraoch
ST_9984783
Team,
We need to display user presence and absence time slot for the 8 hour shift as provided in the attachment. Can you please suggest the widget to be used and solution approach for this in PTC thingworx.
Santhosh
Heaven't done anything similar, but I'd try the following:
Schedule Chart Widget (part of ThingWorx, was introduced in ThingWorx 9)
Gantt Chart Widget (custom extension, was developed for 8.5, if I remember correctly, not sure if it works with 9.0+)
slangley
(To:ST_9984783)
Hi @ST_9984783.
If you found the previous response to be helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
