HI Developers,
I had to merge two infotables and export them into excel. Code is working fine to merge them and export but it is merging alternate rows of both table.
OEE | Issue | Delay | Desc | Percentage | Waste | Degree | Sample1 | Sample2 |
8.1 | Issue | 9.1 | Heating | 12 | 89 | test | testing |
Here we have 2 infotables. one has OEE, Delay, Percentage, Degree. Sample1 and Sample2.. Second has Issue, Desc and Waste
Requirement is to merge it like
Issue | Desc | Waste | OEE | Delay | Percentage | Degree | Sample1 | Sample2 |
Issue | Heating | 12 | 8.1 | 9.1 | 0.12 | 89 | test | testing |
Can we order infotables as per our requirement? Please suggest
if your field names are fixed, then you go and create a datashape [Not using service].
Assuming both the infotable having 1 record.
var newInfoTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
infoTableName: "InfoTable",
dataShapeName: "<NEW DATASHAPE NAME>"
var table1 = [INFOTABLE DATA];
var table2 = [INFOTABLE DATA];
var newEntry = {};
newEntry.Issue = table1.rows[0].Issue;
newEntry.Desc = table1.rows[0].Desc;
newEntry.Waste = table1.rows[0].Waste;
newEntry.OEE = table2.rows[0].OEE;
newEntry.Delay = table2.rows[0].Delay;
newEntry.Percentage = table2.rows[0].Percentage;
newEntry.Degree = table2.rows[0].Degree;
newEntry.Sample1 = table2.rows[0].Sample1;
newEntry.Sample2 = table2.rows[0].Sample2;
newInfoTable.AddRow(newEntry);
result = newInfoTable;
Are you using export with Data Export widget? or any other method?
try to do following..
Hi @Sathishkumar_C ,
Thanks for your response.
I am using this below code.
//Code starts
var tableList = [table1, table2]; // Iterate through the fields of each table, adding the fields to the results table if necessary and then setting the values for(var i = 0; i < tableList.length; i++) { var currentTable = tableList[i]; // Need to convert to json in order to iterate through fields if datashape is not known. If datashape is known, see snippets for potentially simpler solution var table_json = Resources["InfoTableFunctions"].ToJSON({table: currentTable}); for(var key in table_json.dataShape.fieldDefinitions) { try { // this line will error if the field doesn't already exist in the results table... combined_infotable.dataShape.fieldDefinitions[key] } catch(err) { // ...so if it does error, then we need to add it combined_infotable.AddField(table_json.dataShape.fieldDefinitions[key]); } } // Now iterate through the values of each table and copy over each row for(var j = 0; j < currentTable.rows.length; j++) { combined_infotable.AddRow(currentTable.rows[j]); } }
//Code ends
I am using data shape as you have mentioned only. table1 has Issue,Desc, Waste and table 2 has remaining columns.
I checked with loggers till creating datashape, it is making datashape correctly but Second for loop is where it is inserting data alternatively.
Kindly suggest as I am stuck from quite a while now.
var newEntry = {};
Here's a concise and efficient way to do this:
[table1, table2].forEach(t => {
t.AddField({ name: 'id', baseType: 'INTEGER' });
t.rows.toArray().forEach((r, i) => r.id = i);
let result = Resources["InfoTableFunctions"].Intersect({
columns1: 'OEE,Delay,Percentage,Degree,Sample1,Sample2',
columns2: 'Issue,Desc,Waste',
t1: table1,
t2: table2,
joinColumns1: 'id',
joinColumns2: 'id'
/ Constantine
