Network class methods
michaele
Hello I am trying to utilize methods of the "Network" class...  Am having some challenges
I have a network called "CustomerNetwork"  I am trying to  manipulate it through code
one example  removing an entity from the Network
my code for this is
Networks['CustomerNetwork'].RemoveFromNetwork('Store5');
when I test this code I get the following error
Wrapped java.lang.Exception: Invalid parameter type for service: [RemoveFromNetwork] on CustomerNetwork Cause: Invalid parameter type for service: [RemoveFromNetwork] on CustomerNetwork..
According to the class reference the parameter type should be string..  I have entered a string in quotes , In previous tries I have passed a string as a parameter and get the same error...  I have tried several other methods where I needed to pass a parameter and get similar results
paic
(To:michaele)
I recommend you use the snippet.
var params = {
  name: undefined /* STRING */
// no return
Networks["AcmeVending"].RemoveFromNetwork(params);
As you can see it is using not a String in the Service but a JSON Object.
michaele
(To:paic)
Many thanks!!
