Good afternoon,
I'm trying to use the MQTT in ThingWorx Foundation 9.1.0, but I haven't had any sucessfull. I might import the MQTT extension, the problem is the connection with the broker, I can't get it.
Could you help me?
Regard,
Charlo
Hi @charlo
Please refer following article & help center guide to understand how to use the ThingWorx MQTT Extension.
Let me know if you are still unable to establish a connection with the broker.
Sachin
Good morning,
I've followed the help and the article, but I don't get to connect ThingWorx to the MQTT Broker, since the connection indicator in the Thing is red , although I have configured all the needed parameters for MQTT.
Charlo
What is the error you are getting in application logs?
Please confirm the MQTT broker you are using.
Sachin
