No longer be able to receive data from KEPServerEx when changing property from read only to read/write
weli
By default,when binding data with remote thing from KEPServerEx, the binded property is read only. And I can see data coming in. But when I changed this property to read/write mode, It no longer be able to receive data any more. Even I rebind it, there is no new data received.
Anyone can help?
Thanks & Best Regards
Tom
AnnaAn
(To:weli)
Hi Tom,
Indeed I had the same issue per my test locally.
I will open a Jira to R&D to confirm if this is an bug or configuration issue.
I will open a new case for this case to track the Jira progress.
I will contact you through the case thread.
So we could close this thread now.
Br,
Anna
7 REPLIES 7
AnnaAn
(To:weli)
Hi Tom,
Did you try to change Read-Only to Read/Write on ThingWorx Thing Property or from Kepware itself? Make sure that you have configured Read/Write properly in the Kepware side and try again.
Br,
Anna
weli
(To:AnnaAn)
Hi Anna,
Thanks for your help.I changed the status of property inside Thingworx composer. I just tried to change it in the Kepware side, but after selecting read/write, and hitting OK buttion,it changed back to read only.
AnnaAn
(To:weli)
Hi Tom,
Yes I had the similar issue. It's ok when playing with the self created New Tags, it only keep Read-Only for the existing Tags and cannot be changed to Read/Write.
Continue do further investigation and will let you know.
Br,
Anna
AnnaAn
(To:AnnaAn)
Hi Tom,
Some Kepware Tags are Read-Only and are not allowed to change to Read/Write like Ramp Tags.
Did you try with another Tag with a different Address type?
To check which Tags are Read-only and which are Read/Write, you could refer to the Help center:
1. Go to Kepware configuration window
2. Click the "Help" ->"Driver Help..."
3. In my case, I checked Simulator, and then you will see its online Help document
Hope this helps,
Br,
Anna
weli
(To:AnnaAn)
Thanks Anna, just tried Data Type Examples->16 Bit Device->K Registers->Boolean1,found it can be modified to read only or read/write, after binding a remote thing, I can pass value at both side.
But once I changed the read/write mode of this property in Thingwor or in Kepware,the property lost binding, value will no longer pass anymore. I am not sure this is an issue or it should be act like this.
AnnaAn
(To:weli)
Hi Tom,
Br,
Anna
AnnaAn
(To:AnnaAn)
We've got new reply from R&D that this bug will be fixed in ThingWorx 8.1.0; in the new version of ThingWorx, it will not allow to change Read-Only checkbox from ThingWorx platform.
Br,
Anna
