currently I am analysing a Dataset. With most goals I get results, but with two of those features the trained models do not show any results. Eventhough the models are completed sucsessfully, the evalutation Parameters and the Graph stays empty as well as the signals. What could be the reason for this?
Thank you for posting your question to the Community.
Can you provide what version of ThingWorx Platform, ThingWorx Analytics, and ThingWorx Analytics Extensions you are using?
Does this happen with all models, or just one particular dataset?
Neel
It just happened with this dataset.
Currently iam using Thingworx 8.2.3, Extension 8.2.2 and Analytics Server 8.2.1.
What web Browser are you using?
There is a known issue with IE11 where Model details do not get rendered correctly.
Are you experiencing the same behaviors in Firefox or in Chrome?
Neel
I am using Firefox.
Today the same problem appeared with another dataset. Again just two features. For the Number of records i get NaN.
Cedrik
Cedrik,
I see that you are an entitled customer of ThingWorx Analytics Server.
Opening a case with ThingWorx Analytics will be the best path to getting you a solution at this time.
Neel
