I wanted to provide runtime permission to non admin and non member of ComposerUsers group to view the mashup and able to run the application. I have created Organization, in that organization, I have added user group which consists of the user for whom the app should be visible and executable. So as per the article - https://www.ptc.com/en/support/article/CS341872 I have applied the required permissions. But for that user getting error as -
the error you receive is because of the user does not have Visibility for "InfoTableFunctions" (which offers the service throwing the error:
Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
The error you resolve by providing Visibility for the user (or System user) for the entity. Does that already help?
Thanks @nmutter It is working fine now. I have provided visibility and runtime permissions to InfotableFunctions.
Perfect. FYI
- "Cannot call method "xxx" of null" always means visibility for an entitiy is missing (=the entity is 'null'), on which this service 'xxx' is called
- For runtime ServiceInvoke permissions it will tell you more clearly with thingname + servicename
