Not able to delete Analytics extension
drieder
Hello everyone,
i am trying to delete the Analytics extension from my composer. While following these steps, i cant delete the ThingWorx_Analytics_Builder_Extension because "the following Extension entities are still in use: AnalyticsServerFiltersInstance".
Examining this entity i found out it depends on the TW_ML_Helper Thing and thus can't be deleted. So tried to delete the TW_ML_Helpter thing, but this can't be deleted because it is an extension Entity. Also Its services which remove the filters do not remove the AnalyticsServerFiltersInstance.
When i try to forcibly remove the extensions via the ThingworxStorage/extensions folder, these folderes get recreated once i restard tomcat.
Any ideas how to solve this?
Kind Regards,
Dominik
pshubham
(To:drieder)
Hi Dominik,
This is a known issue for the version 8.1 and is fixed in the version 8.2.1.
Prakhar Shubham
4 REPLIES 4
pshubham
(To:drieder)
Hi Dominik,
Prakhar Shubham
I see, i will upgrade then as fast as possible. Thank you
abiidesignss
(To:pshubham)
I have the same problem with version 8.2.1.
Can anyone confirm that? how do I delete the analytics builder extension in 8.2.1.
thank you
 Yes, I'm observing the same behaviour here and can't remove the extension on 8.2.1 and 8.3.0 (upgraded from 8.2.1)
Cannot delete ExtensionPackage [ThingWorx_Analytics_Builder_Extension] because the following Extension Entities are still in use: [entity: AnalyticsServerFilters, used-by: AnalyticsServerFiltersInstance ]]
AnalyticsServerFilters and AnalyticsServerFiltersInstance can't be deleted too - seeing the "Fail - Extension Objects Cannot Be Deleted" and "Fail - Cannot Delete This Entity - It Is Referenced By 1 Other Entities" errors
