Not able to edit or create new action in Thingworx Flow
Velkumar
18-Opal
We have Thingworx flow installed, suddenly we are not able to create or edit action Action in Thingworx flow.
/VR
1 ACCEPTED SOLUTION
Hi @raluca_edu
I have solved the issue. It is due to tomcat version, we upgraded to tomcat 9.0.
Now we are able to create or update Flow.
VR
7 REPLIES 7
Did you change something? Maybe vhost-flow.json ?
Please try to restart Flow service from Services and also Tomcat(Thingworx) service.
After this, if it is not solved, please attach Flow logs (you can try command pm2 logs).
Thank you,
Raluca Edu
Hi @raluca_edu
No I didn't make any changes to Thingworx or Thingworx flow.
PFA the log files and also found below error in inspection window
But when I try to call service using postman I'm not getting any error. PFB PNG
/VR
Thanks for sharing.
Please can you attach <Tomcat>\webapps\Thingworx\WEB-INF\web.xml file?
Did you add/modified web.xml file with any setting?
Thank you,
Raluca Edu
PFA the XML file.
Please comment lines 1060-1068 in web.xml and restart tomcat,flow, nginx services.
Raluca Edu
Hi @raluca_edu
If I comment those line on web.xml, I'm 404 error while opening Thingworx.
/VR
Hi @raluca_edu
VR
