Hello
I am using some customized fonts in our thingworx on premise instance and facing the language issues now after importing it .
The issue is abrupt with some of the widgets where its mix of both the languages.
Hello @KV_10974131 ,
The similar query has been answered previously. You can go through the following community post linked below:
Pls let me know if you have any further questions.
Bhawna
Bhawna
