I'm able to connect a single Thing(Edge) to Thingworx..which works ok.
It is a Thing which is based of a ThingTemplate, which is based of a RemoteThing.
What I'm trying to figure out is how my Edge gets associated with the Thing I created. I got another similar Edge online, with a different Application Key, and it started interfering with the first Edge on ThingWorx.
Any insight into this.Also .. do I need a different application key for each Edge I add?
Gerard, you can use the 'autobind' property in the config.json to automatically bind to a specific Thing. You can also modify the config.lua and set identifiers (you would need to run the luaScriptResource for this), so that they would be unique.
Aanjan.. I'm using the C-SDK. I believe you are talking about the EMS?
I think I figured it out. There are bind API's in the CSDK. Let me check and get back.
Replying to complete the loop.
It is the Thingname in the SteamSensor example. Got it to talk after I changed it.
