When i generate a new dataset, the number of rows tab has a value of zero
These are CSV File and json code
"dataType": "DOUBLE",
"description": "C",
"displayOnly": false,
"fieldName": "C",
"lever": false,
"objective": false
"description": "D",
"fieldName": "D",
"lever": false,
"objective": false
"description": "E",
"fieldName": "E",
"lever": false,
"objective": false
"description": "F",
"fieldName": "F",
"lever": false,
"objective": false
Hi Nuttapol
The issue (or at least one that woudl lead to 0 rows showing) is that you have no field defined as goal in the json file.
You need to have at least one field defined as goal ("objective": true ), so that the engine knows what to predict.
Without a goal, the dataset is indeed loaded as 0 rows.
Hope this helps
Kind regards
Christophe
Hi Nuttapol,
I have 2 questions to help me troubleshoot this issue:
Thanks and Please Advise,
John
John GreinerThank you for answer
1. I use trial version
2. It don't have update log file when i upload dataset
Hi Nuttapol
Hope this helps
Kind regards
Christophe
Hi Nuttapol
I am happy it worked for you.
If you do not mind, it would be useful if you could mark the reply as correct answer so that others facing the same issue will be able to easily find the solution.
Thank you
Kind rgeards
Christophe
