Hi
can we display bar values on each bar in Bar chart/Label chart . should be responsive. please see below snap.
Your property value: ValuesPosition should be set to Outside Bar in Label Chart as in below screenshot:
The feature for adding values to the top of bars or markers in Line and Bar Charts was added in ThingWorx 9.0.
You will not see this feature for 8.5.x OOTB Chart Widgets. Also, per the internal discussions it does not appear there are any plans to update the earlier supported releases with this feature.
Hi @suverma ,
Currently i am using Thingworx 9.1 , I haven't used 8.5.x version. Is it possible to achieve this in TWX 9.1?
Yes you will be able to use it in 9.1 as well. So in my previous comment I meant, the feature for adding values to the top of bars or markers in Line and Bar Charts was introduced from ThingWorx 9.0 and is available for upcoming release after it.
Hope this helps!!
Hi @suverma ,
Can you explore it . how we can show values on top of bar as i am seeing like below chart and hovering on bar will show values but instead i want to show on top of bar.
Hi @suverma ,
I got it, i had other extra columns in infotable which binds to bar chart . i removed those and working fine now.
