How to set maxpagesize as greater than 2000. I have custom odata api which would return more than 2000 records. So I wan t to return all the records in single responce. Please assist.
Regards
Prem
I've found an alternative solution. I'm creating dashboards in PowerBI. The method here provides a fairly straightforward way to iterate through all the necessary pages and assemble them into a single query result using Power Query.
https://www.myonlinetraininghub.com/scrape-data-multiple-web-pages-power-query
You can refer below articles for the information you are looking for,
https://www.ptc.com/en/support/article/CS328466
https://www.ptc.com/en/support/article/CS294238
Thanks Sachin.
But I want to return more than 2000 objects in single response without next link url.
Did you find any solution for this?
Hi @aaronjlarson.
From what I was able to find, 2000 is the max. You can submit a request on the ideas page if you would like to suggest a different value.
--Sharon
