When I try to push data from PLC to Thingworx via OpcUa extension, I receive error which is attached file.
The error said that "receiverBufferSize must be greater than 8192", I checked "Initial memory pool" and "Maximum memory pool" values on Apache Tomcat Configuration, Their values are empty.
Also, I can push data to Thingworx via KepServer but I have problem with OpcUa extension.
Hello, Burak.
That extension is not officially supported, but we can try a few things.
What versions of ThingWorx, the JRE, and the extension are being used? Also can you attach the config.json for the relevant server.
-- Craig A.
Hi Craig,
Thank you for your help.
Thingworx version is 8.0 and JRE version is 1.8.0. Also, I attached config.json file.
