OSI PI and Thingworx Integration
JS_10369742
Hi
I want to connect OSI PI server with PTC Thingworx for fetching the data.
I found below link for OSI PI-Thingworx Connector.
https://marketplace.ptc.com/en-US/apps/229637/osi-pi-historian-integration-for-thingworx
Is there any other way to connect OSI Pi system to cloud based PTC Thingworx?
Here is an article - "OSI PI Historian Integration for ThingWorx 8.5": https://www.ptc.com/en/support/article/CS316167
JS_10369742
(To:VladimirN)
Hi  VladimirN,
Thank You for your reply.
The article which you shared has mentioned some resolution as below:
  • OSI PI Historian Integration uses SDK framework similar to KEPServerEX  to browse tags and templates and query historian
  • There are no direct bindings available
  • Query services can be used to bind to widget
Can you elaborate little bit how this can be used for the OSI PI and Thingworx integration?
So the only way is to purchase a 3rd Party tool to connect to OSI Pi?
