OTA Using MQTT
SwapnilC
8-Gravel
OTA Using MQTT
Hello Folks,
I need urgent help to OTA process using MQTT
our all device connected to Thingworx Using Apache MQTT, Now we want establish process for OTA using MQTT,
Can someone share any idea's around it
Any help appreciated
8 REPLIES 8
Please elaborate a bit on the question.
Do you imply Apache ActiveMQ when saying "Apache MQTT?
What's the reason behind the requirement to use Apache MQTT and not another solution? Normally such decisions are justified by existing expertise within the project team or the enterprise itself, but it doesn't seem to be the case in your story.
What does OTA mean in this context?
What kind of advice are you looking for? Is it technical, e.g. you have particular difficulty with ActiveMQ, or methodological?
OTA : over-the-air update of firmware
currently we are using Apache ActiveMQ for MQTT connection between Device and Thingworx
slangley
23-Emerald II
(To:SwapnilC)
Hi @SwapnilC.
Have you found a solution to your problem?  If not, please provide more information.
--Sharon
Hello @slangley ,
Currently working on development of new firmware for OTA which work over MQTT
slangley
23-Emerald II
(To:slangley)
Hi @SwapnilC.
Thank you for your response.  Are you saying that you have resolved your initial issue?
--Sharon
Yes @slangley
slangley
23-Emerald II
(To:slangley)
Hi @SwapnilC.
Do you mind posting your solution here for the benefit of others with the same issue?
We appreciate your participation in our community.
--Sharon
Hello @slangley ,
Sure i'll post my solution here soon, because currently it's in development phase one's i'll have few screen for showcase everyone then i'll post detailed steps here
