Opacity Blur Effect
ptc-6292144
3-Newcomer
Opacity Blur Effect
Does anyone have a trick to make the images/text behind a Style Definition using Opacity to have a blur effect? I like the ability to have the opacity as it adds a nice look but I would like the make the content behind it also have a blurred effect.
Thank you,
Mike
2 REPLIES 2
I also have this question. May be anyone found a solution in this 3 Years?
In my case I would like to have a glass panel with blurred camera image in the background.
Jonny
jdass
(To:Jonny)
You should be able to add the effects using custom CSS code in the mashup. The ability to add custom CSS was introduced only from ThingWorx 8.2+. Refer Custom CSS Help Center for more information
