As the querypropertyhistory contains a lot of historical data, how can i efficiently get data for a particular time interval and write an optimized code operation.
// dateValue:DATETIME
var dateValue = new Date();
// dateAddDays(dateValue:DATETIME,amount:NUMBER):STRING
var calculatedDateValue = dateAddDays(dateValue, -1);
var endDate = new Date()
var params = {
oldestFirst: undefined /* BOOLEAN */,
maxItems: undefined /* NUMBER */,
endDate: dateValue /* DATETIME */,
query: undefined /* QUERY */,
startDate: calculatedDateValue /* DATETIME */
// result: INFOTABLE dataShape: "undefined"
var result = me.QueryPropertyHistory(params);
Hi Sonali,
If you want to fetch 24 Hrs data you can use above code and if you want interval as Hrs , Minutes, Second you can take it from code snippets in TW.
Hi @SonaliPatro
Just wondering if you're still trying to solve your issue. If you have found a solution, please post it for the benefit of others in the community or mark an existing response as the Accepted Solution.
Vibhuti
