Overwriting an Infotable Property
agondek
I have the following code with which i never assign the variable back to the property however my property on the "Thing" changes to match the service result. Does anyone know why this is happening?
var original=Things["Thing"].Property;
var variable=original;
var newField = new Object();
newField.name = "Setpoint";
newField.baseType = 'STRING';
variable.AddField(newField);
for (var i=0;i<variable.rows.length;i++){
    variable.rows[i].Setpoint=/*somevalue*/;
var result=variable;
Doing that:
or that:
 you don't clone Property contents, you get a reference to it, that's why property it's changing, if you want to work with a cloned copy:
var variable = Resources["InfotableFunctions"].Clone({ t1: original });
Doing that:
or that:
agondek
(To:CarlesColl)
Hi Carles,
That makes sense as far as cloning goes. What troubles me is that operations on a variable in my service only impact infotable type properties. For example, if I use a number property as a reference and then proceed to multiply the variable by 20, in my service, the corresponding property value is not multiplied by 20 unless I assign the variable value to the property.
PaiChung
22-Sapphire I
(To:agondek)
Infotable properties indeed are treated a bit different as well as XML and JSON properties.
This is also why you have to specifically write back the full table to update the property if persisted.
agondek
(To:PaiChung)
Fair enough. Thanks Pai and Carles!
