PDF Download using ThingWorx
Hariharasuthan
hi expert ,
i can not solve problem , please  how to solve problem
var params = {
FileRepository:"filetest/" /* THINGNAME */,
Rotated90Deg: false /* BOOLEAN */,
AppKey: "8204jef3-7l1f-45b7-a2cd-jf55547e7c0e"/* STRING */,
ServerAddress:"http://delbi3dev.analytics.com:8080/Thingworx/Runtime/index.html?mashup=attachment3" /* STRING */,
OutputFileName: "FileName.pdf" /* STRING */,
Resolution:"1240*1775"/* STRING */
Resources["PDFExport"].CreatePDF(params);
 Error executing service pdfRenderingcreate. Message :: Could not launch browser. Build info: version: '2.52.0', revision: '4c2593cfc3689a7fcd7be52549167e5ccc93ad28', time: '2016-02-11 11:22:43' System info: host: 'PTC-DEV-SERV-AWS', ip: '172.16.0.59', os.name: 'Windows Server 2019', os.arch: 'amd64', os.version: '10.0', java.version: '11.0.14' Driver info: driver.version: JBrowserDriver - See Script Error Log for more details.
13 REPLIES 13
Hi @VladimirN
your share link ,all ready share me , this is unsolvable post , please help me.
jBrowserDriver has issues with OpenJDK 11. So I never managed to get the pdf-extensio running with Thingworx 9.x and OpenJDK 11.
I now created another similar extension, that uses playwright web test library instead:
atondorf/twx.pdf.extension (github.com)
Any suggestions and optimisations are welcome ...
Hi @atondorf
you share github link download then export your file(pdfextention) means ,thingworx returning error Anonymous:@unknown,please reffer to another pdf extension
Hi Hariharasutha, can you give me some more details on your comment ...
At github it's only the rough project, yet.
hi @atondorf
 i  try export pdf extension in my thingworx9.3 version but not update .
blow the code
var params = {
Hi @Hariharasuthan, that's the other extension using jBrowser driver. I had the same issue, that's the reason, why i made my own one ...
hi @atondorf
 i  try export your pdf extension in my thingworx9.3 version but not update my widgets, how to add your extension in my widget,
thanks
Hello @atondorf , thank you for sharing your github repository. I am also looking for a pdf extension that works on the newer versions of Thingworx.
So I tried importing your extension, but it gives me dependency error with twx.playwright.extension:0.0.0. Could you provide some guidance?
hi @atondorf , I tried to import the extension but this errror occurred, any idea?
atondorf
(To:pcheah)
Hi pcheah,
yes, you are right ... I normally use the version with Playwright extension already installed and so I did not discovered it.
I forgot to remove the dependency on plawright extension from the "twx.pdf.extension_1.0.0-incl_playwright_.zip".
I fixed it, get it again and try again ...
I you have some expreirence in Java, you are welcome to share optimise this ...
Greetings
Andreas
richie
3-Visitor
(To:atondorf)
Hi @atondorf ,
I'm have imported your extension, but when I tried to "Execute" it run for quite some time (1~2min) and then if I check Application Log afterwards, it shows the below error,
Error: Failed to create driver.
Found some related error:
https://github.com/microsoft/playwright-java/issues/853
https://github.com/microsoft/playwright-java/issues/1256
For your info, my ThingWorx Platform is hosted in VM without Internet Access and it's installed in drive (not the default C:)
I'm not sure if these is affecting it?
Do you have any idea how to resolve it?
YT_10897741
(To:atondorf)
Thank you so much, @atondorf!! A lot of our clients really needed this funcionality and your extension worked for us (Twx 9.3.0).
Hopefully, PTC adresses this need and makes a native extension.
